Post only active setup
Don.Cyr
Don.Cyr
Good morning,
Been working around this but figured I would ask the question.. Is there a way when posting code on a part with multiple setups to post ONLY the code for the active setup without having to remember to click the setup I want the code for? The active setup has a grey box around the setup description, but if I don't click on that setup and turn the box blue, it will post code for all setups, normally I catch this when it gives me a warning for "multiple setups with different WCS has been selected"
Any ideas? Maybe as an improvement somewhere there can be a setting to turn this on/off?
Thank you.
Please click "Accept Solution" if I helped with your question or issue.
Sualp.Ozel
if you are using the "Post process with NC Program" preview /  dialog (available in preferences), try using the "Operations" tab . That may be exactly what you are looking for:
Sualp Ozel, PE
Principal Product Manager
