Hi
Easy solution to not having a 25mm cutter is to just get one 😀 it will not only be way faster to rough the bulk material it will help the inserts in the 10mm last longer as it doesn't have to do so much work
You could be pushing it getting the 10mm to last that long.
Assuming you are using the IC808 grade I would go on the lower end of the surface speed and the higher end of the feed and DOC, this will help the inserts last longer.
Seems the optimal here is the higher depth of cut with slightly lower feed per tooth
Make sure the tool stick-out is to a minimum and using a short rigid tool holder
Ideally use a strong air blast directed at the tool, or through tool air if you have it.(Although Iscar does say you can use coolant with these inserts)
That's giving a 36 min cycle time using the 10mm for the entire pocket, you could probably get double that time(Maybe triple) on one edge of the insert but a would be doubtful you would get 15x out of one edge.(Iscar Reckons 80 mins on one edge)
If you do want to stick with the 10mm you could program the roughing in several toolpaths at different heights with a compulsory stop(M00) in between them to allow you to index/change the inserts.
As for the finishing to achieve optimal tool life the finishing tool should be removing minimal material, say 0.1-.2mm with no large cusps.
So you want to do a semi-finishing toolpath with one tool leaving some stock and then finish with another tool.
Again getting the tool to last will be a matter of getting the Feeds and speeds right, not soo fast that the tool wears out prematurely and not so slow that you get a poor finish.
What that is exactly will need to be somewhat determined by experimentation.
Andrew Laas
Senior Machinist, Scott Automation
