Please decouple spindle direction from tool orientation in CAM
tomae
Message 1 of 11
tomae
I have a back tool lathe and tools can be oriented facing forward or back.  It is impossible to define my tools such that they face the right way (either forward or back) AND the spindle spins in the correct direction.  I have to hand edit all posts to correct spindle direction.
Please decouple the Spindle Rotation parameter in the tool table from changing the orientation of the tool.
-Tom
Replies (10)
Message 2 of 11
HughesTooling
Have you looked at this tab on the tool setup.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 11
tomae
Yes, and when I change the spindle direction the tool flips 180 degrees (on it's axial axis) to the wrong orientation. Hence my plea.
See attached pictures.  Both are wrong.  Clockwise direction gives correct tool orientation, but wrong direction.  Counter-clockwise give correct direction but wrong orientation.
-Tom
Message 4 of 11
jeff.walters
This has already been rported on ticket CAM-3151
Jeff Walters
Senior Support Engineer, CAM
Message 5 of 11
Laurens-3DTechDraw
It's exactly flipped to how they are supposed to be or not @jeff.walters?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 6 of 11
tomae
Message 7 of 11
tomae
Some tools, like my profiling tools, I have been able to orient correctly AND get spindle rotation correct.  For my threading tool and cut-off tool it is opposite. One should just be able to set it and there should be no effect on tool orientation.
Tom
Message 8 of 11
Laurens-3DTechDraw
Actually they should.
I mean the way your tool is set-up says something about the way the spindle should turn.
So coupling them is a reasonable choice.
Laurens Wijnschenk
3DTechDraw
Message 9 of 11
tomae
The design that gives the user the most control is to decouple them entirely.  If it was made a Preference to "auto-select spindle direction with orientation" and it could be turned off, then that would be great.  But as it is it requires that ALL lathe designs and tool orientations be made options and coded correctly  - or incorrectly, in my case.  If I want to design custom live tooling for my lathe will that be integrated into the user interface as well?  I suspect not.  I suppose I can write my own post-post-processor to fix the mistakes Fusion 360 makes, but why?
-Tom
Message 10 of 11
using haas TL2 tool post lathe, I would like to use tools coming from positive and negative x. How can this be done?
Message 11 of 11
Laurens-3DTechDraw
@Anonymous
The only way to do that now would be with a special post processor.
Laurens Wijnschenk
3DTechDraw
