Phantom CNC Router SCA 44 Post Processor
2wheelswelding
Message 1 of 14
2wheelswelding
Hi, I'm looking for a post processor for my Phantom CNC router SCA 44. Currently Fusion 360 does not offer a post processor for this cnc router. Does anyone know where I can find one or have one written for this machine?
Replies (13)
Message 2 of 14
seth.madore
Do you have sample code that you can share, that would give us an idea of what your machine expects to see for code and we can make some recommendations as to what direction you should go. We may have a generic post that will work or it may require light modification.
Seth Madore
Message 3 of 14
2wheelswelding
Sorry, I do not. This is a new machine and CAM is also new to me. I was told by Autodesk that my only options were to buy a custom post or write one myself, which I don't know how to do. Of course another option is to use a different CAD/CAM program. Thanks.
Message 4 of 14
seth.madore
The machine did not come with any sample programs, or at least a programming manual? We can't make a suggestion on which post to use without seeing how the code is laid out. If you have a digital manual, please share it here. If you have a sample program that came preloaded on the machine, share that as well (it needs to have a .nc or .txt file extension).
Seth Madore
Message 5 of 14
2wheelswelding
The machine normally comes with V Carve Pro, which does have a post processor. I didn't purchase V Carve Pro as it doesn't do what I want. I purchased Fusion 360 as I am somewhat familiar with it and it does what I want. I did find a post processor attachment on Phantoms forum that is supposed to work with my machine but it does not. I'd attach it but the extension is .cps.
Message 6 of 14
seth.madore
CPS files can be shared here. What about a programming manual?
Did you buy the machine new? What about contacting the manufacturer and getting a code sample from them?
Seth Madore
Message 7 of 14
2wheelswelding
I'll upload the file. The machine is new but only came with a controller manual for the HD-100 controller. I am working with the manufacturer for a post controller. I will see if they have any samples. Would a post processor from V Carve Pro help? I should be able to get that.
Message 8 of 14
seth.madore
No, but posted code from V-Carve would work. Isn't there a free trial of V-Carve?
Also, what about this post didn't work, exactly?
Seth Madore
Message 9 of 14
2wheelswelding
Sorry, that I don't know. I'm totally new at this. The machine would start and move about 5 inches very slowly back and forth only. The simulation on Fusion Manufacturing worked and looked good so I assumed the post processor I downloaded was not working. That is when I found out that Fusion 360 did not offer a post processor for my machine. It is possible that I did something wrong and it's not the post processor I used. As stated before, I am working with the Phantom sales rep and he also thinks it the post processor.
Message 10 of 14
seth.madore
For comparison, how much should it have been traveling and at what speed? Is it possible that this could be a MM/IN issue?
Seth Madore
Message 11 of 14
2wheelswelding
I will have to check that. I will get back with later today. Thanks!
Message 12 of 14
itsnotlevel7JAHF
No sample code required for any of this. I know this is an old post but I own a Phantom and Grbl post processor works perfectly. Just know that regardless of how you draw in Fusion, you have to create your NC file in Millimeters for the machine to know what its doing. I made that mistake a couple times before realizing and correcting. I would be great if the controller software for my machine.... a rebranded chinese machine.... would work in imperial instead of metric but I have tried to reconfigure and no dice. I love my machine and it works flawlessly but this stuff is just part of growing to understand how all these things work. Theres always a learning curve. Hope this helps someone else in the future.
Message 13 of 14
2wheelswelding
Thanks for the reply. Fusion came out with a post processor for my SCA 44 a
couple of years ago. It works great and you do not have to draw in Fusion
in mm. I draw in inches and have Manufacturing set to inches. Fusion takes
care of the conversion. However, the controller does still only display
in mm for speed and other settings. If you have not tried the Fusion post
processor for Phantom, you might want to try it. I'm very happy with it
and have never had any issues with it. It's good to know that the Grbl
post processor works well.
Message 14 of 14
itsnotlevel7JAHF
Thanks for the Suggestion bro. I am now using the sca post processor you suggested and no more switching back and forth between millimeters and inches.... Thank you!!!
