Pencil Tool path not covering all desired areas
kentdesautel
kentdesautel
I am not able to get the pencil tool path to cover all areas on this work piece. Currently it's going down the corner path on the back wall ( which is what I want ), but I would also like it to follow the bottom curved edge face ( Highlighted in Yellow )
Here is a link to the file:
https://a360.co/4n24BiW
Thank You,
Kent
BobVawter
Add a touch of overthickness:
Use avoidance surface groups if you don't want to process the upper edges.
kentdesautel
Thank You very much for your help on this.... that did the trick.
Thanks again...
Ke nt
