Hi @LibertyMachine, @daniel_lyall, @balancefromwithin,
Thank you for bringing this to my attention! This is not a bug, but rather a workflow issue stemming from the way the component instances were created.
When creating a component pattern in the CAM workspace, Fusion 360 looks for instances of a component rather than the actual geometry of each component. In @balancefromwithin's original post, you will notice that the components in the design are labeled "Component 1:1, Component 2:1, Component 3:1..." When the number before the colon changes, Fusion 360 is defining each of these components as unique instead of as an instance of the original component. This is what happens when you use the "Paste New" command while copy/pasting in the browser tree.
What we would like to do for CAM component patterning instead is use the "Paste" command. This will create instances of the copied/pasted component, which will show up in the browser tree as "Component 1:1, Component 1:2, Component 1:3..." The name and number to the left of the colon defines the actual component, while the number to the right shows the instance of the base component (that was copy/pasted). Using this workflow will allow the CAM component pattern to know that the components are identical instances of the original base component.
I have illustrated this in the screencast below - please let me know if you have any questions!
	Paul Clauss
Product Support Specialist
