Part Crash
Part Crash
Message 1 of 8
Part Crash
This has happened a few time but its so rare to actually catch it in action and get a picture of it happening.
I've attached photos of my problem.
the tool path that 360 is setting out looks correct. There doesn't seem to be any spot in the program that it would take the endmill and ram it into the part we are making. But yet randomly in the middle of the program it takes a hard left a shoots into the part.
if someone could help us with this problem we have been having it would be greatly appreciated.
Replies (7)
Message 2 of 8
al.whatmough
This looks like a dogleg rapids issue.
What machine and post are you using?
Al
AL Whatmough
Director Product Management - Manufacturing
Note, I love to engage on the forums. However, I spend a lot of time in meetings trying to help clear the path for our amazing team of Developers working on Manufacturing at Autodesk. So, if I don't respond immediately, it's not that I don't care.
Message 3 of 8
Machine is a Haas-TM3, so we are using a Haas post processor.
Message 4 of 8
al.whatmough
In the post dialog you should have a property "use G0" is that set to no, it should be.
AL Whatmough
Message 5 of 8
jeff.walters
A dog leg move is where instead of moving in a straight line from point A to point B, the machine kicks both axis motors on max so the machine makes a 45° move then finishes the long move. But when moving at a feedrate the machine goes straight from point A to point B. This is very common on HAAS machines. Because of this issue HSM has an Always use high feed option on the linking tab.
Jeff Walters
Senior Support Engineer, CAM
Message 6 of 8
We are going to take the G0 out and run a test part we will update to see if it fixed the problem.
Message 7 of 8
CHANGE G0 IN POST TO NO, LOOK GOOD
THANK YOU FOR YOUR TIME AND HELP
Message 8 of 8
al.whatmough
I am glad that fixed it.
As Jeff metioned, the other option is to Force it in the software.
The "Use G0" parameter in the post is our FAIL SAFE to catch any Rapid move that moves in more then one Axis at a time is converted to a highfeed move.
This insures you will not get dogleged rapids.
AL Whatmough
