Parallel tool path issues
for some reason it wont let me select the entire rectangle where i want to contain the tool just the one side so as a result it wont calculate the tool path ........ file attached below
Mattxer
Hello!
Are you sure the tool orientation is correct? I just opened your project and the tool is not normal (perpendicular) to the box.
Before:        After:
Matt Smith
Software Engineer - MSmithDev - https://msmithdev.com/
CAD/CAM/CNC - Micro Insert Inc. - https://microinsertinc.com/
johnswetz1982
You need a sketch perpendicular to your tool direction. It is currently inline with your tool orientation. Either switch your tool orientation or make a new sketch for the one you have.
hey thanks man
