Over Lap Tool Path
Over Lap Tool Path
alan
Message 1 of 17
Over Lap Tool Path
alan
I have another question on the same part as yesterday so I can not share the file.  While doing an 2D adaptive to mill a square I want the path to over lap.  At the start point there is a tiny amount of stock left.  I know I've seen this feature put can't seem to find it.
Please help.
Replies (16)
Message 2 of 17
vid.kok
Hi Alan,
To acquire the file go to File > Export > Save to my computer and then attach the file to your reply.
Message 3 of 17
alan
Thanks for your reply.  Soory, I can't share the file because of a NDA.  Do you know of the over lap setting?
Message 4 of 17
vid.kok
I don't understand what specifically you mean when you say that you want the path to overlap. If you could take a close screenshot of only a section of the part that would help.
Message 5 of 17
alan
I would like the the path that cuts a square to over lap.  The tool was a start point and an end point.  Where those two meet there is a little stock left.  If the end point went say 0.050"  past the start point the little area of stock would be gone.
Thanks for your help.
Message 6 of 17
martin.dunschen
Hi @alan unfortunately there is no option to extend the end of paths to overlap other areas in 2D or 3D Adaptive Clearing. Also, I am surprised that you find that there is any stock remaining? If you can't share the part, could you perhaps create a simplified version of the example with the square you want to machine and where you find this stock issue?
Martin
Message 7 of 17
alan
Okay, thanks. I thought about a year ago I was doing 2D adaptive clearing that left some round islands and there was an option to overlap. Is that a possibility?
Message 8 of 17
martin.dunschen
Hi
No, we never had the need of creating overlaps by path extensions in Adaptive Clearing. I am still curious to see this problem you describe in an example, so if you (or anybody reading this thread) can come up with an example they are able to share, that would be great.
Martin
Message 9 of 17
alan
Okay, here's a sample.
Message 10 of 17
alan
Martin,
Now that I have a little time the picture shows the left over stock.
Message 11 of 17
martin.dunschen
Thanks @alan, I'll take a look at it as soon as possible. The picture is very helpful.
Martin
Message 12 of 17
Steinwerks
I opened your file and noticed this is where the stock is left:
If you turn on Stock Contours on the Geometry tab as such:
There is no stock remaining gap as before:
That doesn't explain the remaining stock issue, but at least it's a workaround for now until @martin.dunschen takes a closer look.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 13 of 17
zodiaceng
It may have been mentioned already but 2D Adaptive is a roughing toolpath only. You need to use 2D Contour with Finishing Overlap in the Passes tab for this.
www.zodiaceng.com
Message 14 of 17
alan
Neal,
Thank you.  Good call that works perfectly.
Message 15 of 17
alan
Zodiaceng,
Thank you.  I knew I had used that before.  That solves it but am still thinking Martin will figure out why adaptive clearing was leaving a little stock.
Message 16 of 17
martin.dunschen
Hi @alan and others
I've now created a ticket for this issue, there are unexpected amounts of stock remaining, as you reported, ticket number is: CAM-9351.
Thanks again for reporting this problem and taking the time of creating a simplified part to show what is going on. I appreciate this very much, especially given that you started seeing this in an NDA part, but now shared a design that reproduces the problem.
I hope to work on this as soon as possible.
Martin
Message 17 of 17
alan
Martin,
You and The Fusion Team are welcome.  I am very pleased with your product.  Fusion has opened up some big opprotunitites for our company.
