Output G2 and G3 in each circular movement
luc_dewitS5BZT
luc_dewitS5BZT
I use the fanuc post for milling but I need in each circular line of the program G2 or G3. At this moment the post wright only at the first line G3 when I have more then one circular movement.
How can I solve this in the post?
serge.quiblier
Hi @luc_dewitS5BZT
we are using modality for the output of the move command.
In order to avoid that, in the begining of the onCircular function, you can add a line:
gMotionModal.reset();
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
luc_dewitS5BZT
It works. Thanks a lot for your input.
