otpimal setting cam
02:48 AM
hi,
I have some parameters to be set to obtain a correct processing with cam:
1) putting at zero the mill on the top surface of 15 mm Slot starts with 1 mm gap in more, in this way the bottom of the cavity length 16 mm from the cleared surface.
2) The radius are trimmed as attached photo and horizontal machining non fill up the gap between past contouring with 0.15 mm, T6 R1, and horizontal machining with same mill
P.s. in the picture was taken off the part of 1mm of stock at most after the contouring
Best Regards
Giorgio Guidetti.
