- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I am currently working on achieving the optimal speeds and feeds to meet a specific surface roughness requirement as outlined in a detailed drawing. Could anyone suggest how manufacturers generally calculate the specific speeds and feeds for different materials to achieve this? Additionally, I would appreciate any resources, articles, or recommendations on how manufacturers approach this process. Any insights or references would be helpful
For Example, For a Facing operation, the surface roughness range is Ra 6.3 - Ra12.5, and also in the different pockets the roughness specified is Ra 25 so how can I change the feeds and speeds accordingly using the same 20 mm Flat end mill, The material I am machining is Grey Cast Iron
