Operations not appearing in CAM with no error messages.
Message 1 of 10
Hello!
I am attempting to generate engraving toolpaths and Fusion just won't do it. It seems the problem happened within the last week.
I can generate a setup. I can then attempt to choose an operation such as engrave. I fill out all the operation details and click OK and nothing appears underneath the setup tree. I tried playing around with different tool sizes etc, but I'm not even getting a "failed to generate toolpath" error. I tried to modify an existing operation and I cannot. I go to edit the operation and I can change the  features and they just revert to the prior toolpath. I've reinstalled a couple of times but the behavior remains. I'd love some advice!
Replies (9)
Message 2 of 10
seth.madore
Let's start with some screenshots and a Screencast if you don't mind. I don't think this is an issue at the file level (yet).
Asking the obvious, but is this arrow collapsed?
Seth Madore
Message 3 of 10
My model seems fine. The issue is with attempting to generate new operations. I've tried reinstalling a couple of times.
Thanks for your help!
Ted
577329ca-3389-49fa-9abd-1b6f6fb52600,640,680
Message 4 of 10
Message 5 of 10
seth.madore
Can you share that file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
Message 6 of 10
I've also tried to generate pocket toolpaths, but they just don't take.
Message 7 of 10
seth.madore
This is what I receive when I follow your steps exactly:
I'm stumped....
@jeff.pek any ideas?
Seth Madore
Message 8 of 10
jeff.pek
I looked under the covers at both of the documents attached. The "Radiation Box Top Plate v12.f3d" only has a setup, and no operations. The "Untitled v4.f3d" has a setup plus 4 operations: 3 engrave, and 1 2d pocket. When I open that model I see all 4 operations.
Are you not seeing that when you open that model?
Jeff
Message 9 of 10
seth.madore
Oh, I see the same as you. It's just that I can create a toolpath and it shows up, however the OP in their screencast is showing different
Seth Madore
Message 10 of 10
I have tried working with Fusion on another computer and it works nicely. Must just be my machine.
I've tried reinstalling the program but the behavior remains. Is there anything special I can do there?
Many Thanks!
Ted
