Operation Cycle Time
info99H4D
info99H4D
Since the latest update Fusion no longer displays the cycle time of the selected operation in the bottom right of the screen.  This was quite a handy feature I was quite fond of.  Is it a setting somewhere that has been changed or has the feature been removed?  If so is it possible to get it back?
I know I can right click and select machining time but it was such a quick and easy way to keep tabs on things - especially useful when making changes to a cycle to see how it impacts cycle time.
a.laasW8M6T
Hi
It still displays fine for me
What version of Fusion are you on?
I don't think there is any user preference for this display(there is one for displaying the time in the Browser)
Andrew Laas
Senior Machinist, Scott Automation
info99H4D
Thanks for the quick reply.
I'm on version 2.0.19966 x86_64
Interestingly it looks as though the information has been cut off for some reason.
a.laasW8M6T
Hi
If you restart fusion does it fix the issue?
I would check that your graphics Drivers are up to date
Other than that I'm not sure what to suggest
Andrew Laas
info99H4D
Turning it off and on again did the trick 😅
Thanks for the suggestion!
