Open passes are linked with both ways zig-zag ramp
I am contouring in 2D with a limit (stock contour), multiple-path and ramp lead-in. It generates an open path with the following warning:
And so the toolpath is going back and forth as if I had ticked the "both ways" checkbox. Not a big issue in this demo project but on a bigger one, the toolpath is going back contouring the whole contour instead of going up/out from the stock and to replace itself at the beginning of the contour.
How can I make the tool enter with ramp, do the contour, go up/out and move back to origin, enter with a ramp to do the 2nd pass contour, go out etc
Without ramp option, the toolpath is doing it as expected
Demo project: https://a360.co/3f0S5hb
ChristopherMarion
@Anonymous
It is a bit odd, not sure why the tool will not retract between passes.   It looks like the sketch boundary is causing this issue.  I also noticed that you programmed with conventional cutting rather than climb cutting.  Not sure if that was on purpose or not, but it had no effect.
I tried a 3d contour and it looks like it does the job and you have the ramp control you are looking for.  Here is a link to the updated project.......https://a360.co/3e9PTTt
Hopefully this is what you were after.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
Well it is nearly how I wanted to be but the tool was entering into the stock in the middle of the toolpath. By setting a 10deg ramp, it worked as expected.
Thanks for the workaround but I would like an admin to take a look and make a bug report because it doesn't make sense to make a 3D contour where a 2D contour should make it!
My bad: with 10° ramp, it is not making any ramp at all...
ChristopherMarion
@Anonymous
What about 1 degree ramp?
And I agree, this is just a workaround.  I'd report this through your Autodesk account so development is aware.
Christopher Marion
SolidCAD - Canada
