[OPEN] Looking for feedback - Additive Multi-Axis Deposition extension preview
robert.bowerman
Autodesk Autodesk
Message 1 of 26
robert.bowerman
Hi everyone,
As of the November 2021 update, we have released an extension preview for Additive Multi-Axis Deposition toolpaths in Fusion 360. These toolpaths are primarily aimed at driving machines with Directed Energy Deposition technology and enable Fusion 360 users to deposit material onto planar, cylindrical, revolved and arbitrary surface types.
To access this functionality, head to your preferences, preview features and turn on the “Additive Multi-Axis Deposition” feature flag.
A complete walkthrough of the workflow can be seen in the following tutorial:
Fusion 360 Additive Multi-Axis Deposition Toolpaths
We’d really appreciate your feedback on this functionality, so feel free to share your thoughts, comments and ask questions in the following thread.
Thanks in advance,
Rob
Replies (25)
Message 21 of 26
gostred22
Hi all
I am trying to 3D Print with the following objective:Objective.jpg
I have a 5 axis machine setup, which mechanically should be able to do it. In this case, ideally the extruder would be always parallel with each face of the base feature when printing the first layer. Is it possible to create this effect?
Message 22 of 26
robert.bowerman
Hi @gostred22 ,
Yes, it is sort of possible but you need to add a small radius to the edges of your cube. This is a result which I've calculated with a 0.1mm rad.
Rob
Message 23 of 26
gostred22
Hi
Thanks alot for checking it out! Could you please share an example file of how you managed that?
It would be really helpful.
Thanks in advance!
Message 24 of 26
robert.bowerman
Hi @gostred22,
Perhaps a quick call would be easier, if you can drop me a private message lets set up a time to talk.
Rob
Message 25 of 26
velkejtom
Observer
Observer
Hi everyone,
I try the DED feature using Autodesk Generic DED machine. The idea is to export trajectory to RoboDK for further optimisation and robot code generation there.
No problem with feature generation on flat or convex surfaces, but on concave surface the path generation starts, counts to 90% and never ends without any error message. I tries several times, still the same.
Message 26 of 26
rakshith_badarinath
Observer
Observer
Hello Fusion Team,
I have been using Fusion360 for a while and I have the following questions about the capability for Additive toolpath generation:
1. How can I go about setting up a 4-axis DED machine? Looking for capabilities to print on a shaft.
2. For the additive process, Is there an option to control perimeter and infill widths?
