forgive the dopey terminology in the title but here goes
i need to clear material from an odd shape pocket where the corner radius is only 1mm, clearly i dont want to clear the entire pocket with a one mm end mill when i can get a 4mm in there to rough it out, im sure there must be a function to tell the machine to rough it out with the bigger end mill then finish off in the corners and maybe smooth the sides at the same time, i understand there is a stock to leave function is this the right idea? if so how do i set the toolpath the rough out then pause whilst i change end mills (its a chinese cnc router)
thanks
