- Mute
- Permalink
- Report
Hey Folks,
So I've got this part, it's basically a 315 x 136 x 7mm rectangle. And on the bottom face of this rectangle (one of the 315x136 surfaces) I've designed some notches at a certain point along the edge. Since I'm going to have a bunch of other features on the other such face, this side will be my "back side" which I'd like to mill first. So, when I ask 3D adaptive to tool path out this side, using a 0.3mm fine step down I get something that looks like it's going to make my desired shape. But, when I come back with a smaller bit on a copy and pasted version of the operation and use a 0.1mm fine stepdown you can clearly see that Fusion has no intentions of milling my geometry. Then, when I try to clean up that mess with a scallop rest mill it seems to want to skip this patch in the middle.
-Dan.
