- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I just had something strange happen with fusion 360. I designed a small part, worked out the machining and posted the process just like Ive done before with success. This time when I load the .nc file onto the controller, and try to start the program, the Tormach PCNC 1100 controller gives the message:
file/home/operator/g code/FA.nc is not a valid G code text file format
I also tried an older program that I used on this machine and setup previously successfully, and it gave me the same message.
Obviously I have inadvertently changed something because it was working before, but I cannot figure out what it is. If anyone has any ideas, I would sure like to hear them. Thanks in advance for any help or advice. Im using fusion 360 and a Tormach PCNC1100 with a controller running path pilot. Please find attached file FA.nc (the offending file)
