NO tool change or even stop to manually change in the post g-code
Message 1 of 8
Hello, I'm SUPER STUCK! I have been away for about 6month laid up having surgeries and now I'm back and F360 is not posting any code to call to pull any tools fro ATC. Hell i cant even get it to stop for a sec so I can manually do it myself just so i can get my crap done. As of now I am having to do every op as a single op.. this blows what am I doing wrong that I wasn't before? I feel like something has changed but I cant find it!?!?!?
I'm using a Tormach PCNC 1100
HELP
MoBo
Replies (7)
Message 2 of 8
seth.madore
Tick this box
Seth Madore
Message 3 of 8
Hello. I have tried that both ticked and in- ticked same result. Oddly even when I tick the “Option stop between Ops’s” & “ optional stop between tools” it doesn’t stop either. It just goes up to g30 home and then with out a pause or motor slow it starts right back down to next op. I have been running most ops today in conv. On my Tormach and everything runs fine but I don’t get all the details and option I designed in F360.
Message 4 of 8
daniel_lyall
Wich control program does it use Mach3 or Path pilot
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 5 of 8
Pathpilot both on ver from last year and news version both same issue. I looked thru the gcode and the is no M6 in it any where. Whether I tick the button or not it is not there. I even looked at it in an outside gcode editor and it was the same. No m6. I’m going to look more to see if the other m codes are there that make it stop/start after ops. Long day of single ops and running everything off machine.
Message 6 of 8
boopathi.sivakumar
Hi @Anonymous
Its very strange, I can't able to reproduce the issue.
In the properties box M6 needs to be ticked
Boopathi Sivakumar
Principal Manufacturing Engineer
Message 7 of 8
daniel_lyall
Can you do a video on your prosses from posting the code to checking it, it could be a prosses problem.
Also, can attach the post and a file where you have this problem.
A simple quick thing to try grab the path pilot post from here https://cam.autodesk.com/hsmposts?
and stick it in your assets - CAMposts make sure you have enable cloud library ticked.
Daniel Lyall
The Big Boss
Mach3 User
Message 8 of 8
seth.madore
Can you share your file? Is it possible that you have assigned identical tool numbers to multiple tools?
Seth Madore
