No retract after tool change.
nathandaydesign
Message 1 of 9
nathandaydesign
Hi. We've recently changed from a cnc with manual tool change to auto tool change. However after a tool change, the spindle doesn't retract before starting the program, which will result in a collision with the bed.
We have so far been able to add the retract to the g code manually, but looking for this to become a default setting.
The machine manufacturer has suggested this is a Fusion issue.
It has a Syntec processor.
Any advise would be greatly appreciated.
Replies (8)
Message 2 of 9
seth.madore
What codes are you manually?
If the G28 isn't working for you (it "should" be retracting home), you might need to swap to the G53 option.
One other thing; you are using the Syntec post processor, right?
Seth Madore
Message 3 of 9
nathandaydesign
Thanks for your reply. I tried both, G28 and G53 and it still doesn't produce a save retract after the tool change. And yes we have a Syntec controller unit and using the default Syntec option for the NC code
Message 4 of 9
nathandaydesign
Hi Seth, Any more thoughts on this?
Message 5 of 9
da_fish
Good Morning, What kind of machine/tool changer are running that you need a retract after tool change? Or did you mean before? Usually the machine will retract on a tool change. I posted out a program with the Syntec Post and it outputted retract before each tool change as I would expect.
Here's the code I got.
Message 6 of 9
nathandaydesign
Thanks for your reply. See attached. We had the tool changer positioned moved from its original position on the gantry to preserve usable z axis height. Now it's level/below the bed.
Message 7 of 9
nathandaydesign
Obviously it's needs to retract after the tool change to avoid running into the bed.
Message 8 of 9
da_fish
Hey I'm back,  Attached is the Syntec post from the library that I modified.   I added line 828 and 829.  This should work for you, let me know.
Message 9 of 9
nathandaydesign
Thanks heaps- Much appreciated! Will run this and report back.
