No G28 in the beginning
Message 1 of 8
Does anyone know how to modify a generic post processor, like Fanuc to disable G28 in the beginning of a program? Our company doesn't need it.
N10 G90 G94 G17 G49 G40 G80
N20 G28 G91 Z0.
N30 G90
How to remove N20 and N30 blocks?
Replies (7)
Message 2 of 8
daniel_lyall
Set show sequence numbers to no for N10, N20 so on that will stop N, why G28, it can be removed with a post processor edit
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 8
GeorgeRoberts
Thanks for posting. The G28 safe retract line is put in the post processors to ensure the machine is at a safe Z position prior to any movements that could cause issues. If you would like to remove the G28, please ensure you enter in a sensible safe retract line to replace it.
Cheers
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
Message 4 of 8
I figured it out: moving the } to new place. Thank all of you!
// stop spindle before retract during tool change
if (insertToolCall && !isFirstSection()) {
onCommand(COMMAND_STOP_SPINDLE);
// }  (removed } )
// retract to safe plane
retracted = true;
writeBlock(gFormat.format(28), gAbsIncModal.format(91), "Z" + xyzFormat.format(0)); // retract
writeBlock(gAbsIncModal.format(90));
} //added } here
Message 5 of 8
GeorgeRoberts
Thanks for posting your progress. Moving the bracket there will still output G28 on toolchanges (if it is not the first one). You can comment out the single line by using two forward slashes '//'. To actually remove this line, change it from this:
to this:
// writeBlock(gFormat.format(28), gAbsIncModal.format(91), "Z" + xyzFormat.format(0)); // retract
George Roberts
Message 6 of 8
schlotterbeckmachine
This solution removed G28 from the beginning only, correct?
Message 7 of 8
daniel_lyall
Depending on what is in the post now a lot of posts are different now compared to 2 years ago.
Daniel Lyall
The Big Boss
Mach3 User
Message 8 of 8
In this particular case it is generic fanuc turning that's had some edits made. I'd like to keep G28 prior to tool changes but want it cut out at program start.
