newbie fadal post issues please help
laboit1
Message 1 of 14
laboit1
im using the fadal post below it seems to work okay it just will not set the right spindle oriantation if any one has some insight or has a post that they will share that works  it would be greatly appreciated Thanks Adam
machine is 3016 fadal 1998
calmotion
Replies (13)
Message 2 of 14
laboit1
here is the post im using now not sure why it didnt attach
Message 3 of 14
Steinwerks
What do you mean by spindle orientation? Tool orientation? We have a '97 VMC2216 and there is no spindle orientation function (beyond M19 for say a tool change) on ours or any that I'm aware of.
If you need an M19 output somewhere that's different.
What error do you get when you post a program?
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 4 of 14
laboit1
Thanks for the fast reply you are correct after reading others post the m19 is what we needed for the tool change so the post is runnung great the second problem were having is at the end of a simple drilling program the drill will stay at 0 and we need it to retract 1.5 to clear another portion of the part any advise would be greatly appreciated Thanks Adam
Message 5 of 14
jeff.walters
what do you have your feed and retract heights set to?
Jeff Walters
Senior Support Engineer, CAM
Message 6 of 14
laboit1
I have them set at 1.00 and it will bring the tool down to the o position and move across the part and at the end of the cycle it brings the tool back to the zero position and moves back to xoyo
here is a copy of the practice program im running and the post normally at the end of the program it will move to the z home position and x0y0 im not sure if this is a post issue or a program issue Thanks Adam
Message 7 of 14
Steinwerks
Well here's a big problem:
N60 G90 G0 X2.1057 Y-1.2316
N65 G43 Z0.6 H0
N70 Z0.2
N75 Z0.1375
N80 G1 Z0.1 F14.56
You're not using any tool offsets, and I assume you're using the E offset for Z? As long as E1 is the work offset everything will go there until either a G28 line or E0 line.
Are you running Format 1 or 2? I would suspect 1 due to the E offset usage.
Neal Stein
Find me on:
Message 8 of 14
laboit1
format 2
Message 9 of 14
laboit1
good morning here is a simple program that works great that is written with mastercam I would like to get a 360 post that will output in this format if at all possible I will pay for this setup we love the 360 software we just need to get a post that works for our machine Thanks Adam
Message 10 of 14
jeff.walters
Before we go and have the post changed can we see the part you’re trying to cut? It could be that you have a setting wrong to get the output you’re looking for.
Jeff Walters
Message 11 of 14
laboit1
Yes that is no problem it is just a simple square with a 2 inch hole Thank you so much for the help im about to pull my hair out I have tried several posts
Message 12 of 14
laboit1
here is a marked up nc file that i hand modified that works the way I would like the g43 h tool number etc Thanks again for the help
Message 13 of 14
jeff.walters
What I found is that you have your length and diameter offsets set to 0.
When I set them to 3 (to match the tool number) I get the output below. Please try setting the length number post in format 2 and see if it runs.
O1001 (N)
(T3 D=0.375 CR=0. - ZMIN=-0.375 - FLAT END MILL)
N1 G90 G94 G17
N2 G20
N3 G28 G91 Z0.
N4 G90
(2D ADAPTIVE2)
N5 M9
N6 T3 M6 H3
N7 S3676 M3
N8 G4 P49
N9 E1
N10 M8
N11 G0 X2.1057 Y-1.2316
Jeff Walters
Message 14 of 14
laboit1
Good morning Thank you so much that is what we needed I thought it just had to be something simple Thanks to you and all of the 360 team
