New "Order For Shorter Links" doesn't seem to work as intended?
BWENGUK
Message 1 of 9
BWENGUK
Just trying out the new "Order For Shorter Links" which is something I've been wanting for ages. But it doesn't seem to work how I would have expected it too. This is a very basic example, but I have a 50mm tool set to do 20mm stepovers. The first 'front' cut is correct, however the second 'back' cut ends up doing pretty much a full width of cut, ignoring the 20mm step over.
I assume it is essentially just generating the old style tool path which works from one side across, but then changing the order of the cuts? Rather than creating a new tool path that should be working from each side in, until it meets in the middle.
I have added some screenshots below. Hopefully this makes sense. I was looking forward to this new toolpath, but as it's currently implemented, I can't see it being useful at all, as you seem to have no control over that cut at the back!
Replies (8)
Message 2 of 9
seth.madore
You raise a good point and I think this was overlooked when implementing this feature. I've raised a ticket to improve the behavior; CAM-54081.
Thanks for trying it out and sharing your feedback!
Seth Madore
Message 3 of 9
Ks-bart
 hi @seth.madore ,Another issue is when you select "use chip thinning" togheter with "order for shorter links" the direction "climb milling " is no longer valid!
So with multiple passes, the first pass is climb, second conventional, our mills really don't like this 😉
Message 4 of 9
seth.madore
If you update to the latest Production release (just came out last night) you will find that both matters should be resolved 🙂
Seth Madore
Message 5 of 9
Ks-bart
hi Seth, that's weird, I tested this yesterday before and after updating to
Fusion 2.0.20256 x86_64
combining  "Order For Shorter Links" with "use chip thinning" , no change for me, still climb-conventional-climb
Message 6 of 9
a.laasW8M6T
I just checked this now and its working Fine for me.
Can you share and example .f3d where this isn't working?
Andrew Laas
Senior Machinist, Scott Automation
Message 7 of 9
Ks-bart
I've attached a f3d...
the problem only occurs if the mill ends on the other side as where the start point is, so with unequal passes
Message 8 of 9
a.laasW8M6T
Ah yes I see, and multiple depths
My test had an even number of stepovers and also no multiple depths.
Your example file should be good data for @seth.madore to report this.
Andrew Laas
Message 9 of 9
seth.madore
Thanks @a.laasW8M6T and @Ks-bart, I've opened up CAM-57065 to investigate the issue
Seth Madore
