autodesk xyz post processor
javelinjim
javelinjim
is it possible to alter the autodesk xyz post processor to add a GOTO/ before each coordinate line and change the separator to a comma and then save the post as a .apt to work with my machine?
seth.madore
This post processor?
https://cam.autodesk.com/hsmposts?p=xyz
Seth Madore
javelinjim
yes that is the post . i need to add GOTO/ to each coordinate line.
GOTO/51.111252, 50.793751, 150.
BWENGUK
If you open the post processor to edit it, this would be a relatively easy change.
function onOpen() {
  setWordSeparator(";");
would change to
function onOpen() {
  setWordSeparator(",");
and then:
function onRapid(_x, _y, _z) {
  var x = xOutput.format(_x);
  var y = yOutput.format(_y);
  var z = zOutput.format(_z);
  if (x || y || z) {
    writeBlock(x, y, z);
would change to:
  if (x || y || z) {
    writeBlock("GOTO/", x, y, z);
Or there abouts anyway!
javelinjim
the write block moves the x,y,z to y ,z ,i when i look at the data on the machine editor
javelinjim
is there a way to get xyz values from set up zero instead of the point locations?
javelinjim
if (x || y || z) {
writeBlock("GOTO/" +x, y, z);
when adding the goto with a comma separating it it moved my data to Y,Z, I , so i added the + instead and it worked great.
