Nesting studies with huge computing times
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm really struggling with the nesting in fusion. The study contains 30 slightly complex spline-based components, some with pocket features, but nothing crazy IMO. You can see the nest settings attached. The settings for the parts are the same, and bind/unbind doesn't seem to do much difference. I actually can complete studies, but computing times are more than 3000 seconds in some cases, and I can't complete a study at sufficiently fine increment settings for the job. I feel like I've tried everything; different setting in nest preparation, setting very "unambitious" values in the nest study computing settings, clear cache.. you name it. I can tell the CPU is working at roughly 15% throughout the 2000 seconds of the study, using around 3 cpu cores at any point, so it is doing some work. I have used other Cam software and nesting functions and know this kind of jobs should be possible to calculate in no time. I could go on speculating about all the possible causes, but I hope someone can look into the file and see what I don't.
