Nest loses circles when exported as DXF
r.moss
r.moss
I have been using the Nesting and Fabrication extension to create laser-cutting patterns.  One of the items is a hexagonal hatch cover with 6 holes.    In Fusion 360 it looks like this:
When I export this sheet as DXF and open it in AutoCAD LT (or CorelCAD, for that matter) the hexagonal hatches only have 4 holes:
Very annoying!
The nesting file is here: https://a360.co/3wmGYKV
engineguy
@r.moss
There is no file at the upload location of your link. Can you try exporting it via this route, go to :-
File > Export > Select .dxf format > Save to a location on your computer > Then attach to your reply using the "Attachments" function below your reply box.
Have you tried exporting it as a .dwg file ??
.dxf files are notorious for their inconsistency as regards opening properly in other Softwares 😞 😞
