Nest fails, even though all parts can fit.
PeterGCM6M
PeterGCM6M
While trying to nest 3 components on a 59"x 23" sheet, The nest errors with not all components fit. The two components that are 19x9 will be nested, but it fails to place the 53" by 3" rail. If I make the sheet  23.05" (.05" bigger) all components nest correctly. The screenshots below show the error in more detail.
Screenshot 2023-12-05 161527.pngScreenshot 2023-12-05 161620.pngScreenshot 2023-12-05 163921.png
jhackney1972
If you can share your model, that would help someone, with a Nesting License, to try and troubleshoot the issue.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
PeterGCM6M
Attached is the file I am using, the two larger models were imported via the component sources tab. if they fail to load for you I can make them part of my base model. While playing around some more, I noticed that it generates correctly if I select minimize width. But if minimize length or length x width is used, it fails to incorporate all materials in one 23" wide sheet. If the sheet stock is changed to 23.05" wide, all components get incorporated regardless of how I select to minimize sheet usage.
seth.madore
Which file am I looking at?
the first one (Headliner) doesn't have any errors on the Nest study.
However, the Upper Rear most certainly does:
Seth Madore
seth.madore
Disregard. A re-read of your initial post and followup gave me the clarity needed. Investigating..
Seth Madore
