- Mute
- Permalink
- Report
So I'm trying to set my CNC mill up for CNC turning (with the part chucked into the spindle). I've created the below test part. You can see the extra stock on the left end where it would be chucked into the spindle (round end facing down towards the table). Origin is set to "stock front".
Ok, so you can see the Z axis is pointing down towards the table. Normally when I do CAM for milling operations the Z is pointing up towards the head. As it is the tool is oriented correctly with respect to the spindle rotation.
But if I flip the Z axis in the setup it also flips what is front/back of the stock/model. This also results in the cutter being backwards with regards to the spindle rotation. See below.
I'm confused how to set this up correctly. I can probably account for this in my machine settings but it would be nice to not have to switch machine configurations between operations.
Somebody tell me the setting I'm overlooking :). Thanks!
