Need a 4th Axis Post for a DIY Machine with Mach 4
boyd.sofield
Message 1 of 15
boyd.sofield
I've read a lot of threads and seem to only come up with posts and info about posts for machines that are manufactured. I have a home built router and want to run a 4th axis. Ive been looking at many threads on how to edit a post to suit but not being a coder am not having much success.
Wondering how I go about getting hold of a Mach 4 Post that will publish a program for my 4th Axis. I cant afford the machining extension but I do want to use the wrap and indexing options.
I also need to set it to rotate in the Y Axis not the normal X
An alternative is pointing me in the direction of a good page I use to help me make the edits I need too on the original Mach 4 Mill post. But I have not had much success in the past.
Replies (14)
Message 2 of 15
AdamKunzo
If you want send me a message, I offer post processor modification as a service and I can help you to customize post processor for your home built machine.
Message 3 of 15
engineguy
@boyd.sofield
Try the attached Post Processor, it is one I used a while ago for Mach4 with wrapped toolpaths and I have set it to rotate around the Y axis for you, just give it a try, carefully, may work for you 🙂 🙂
Message 4 of 15
boyd.sofield
Hi many thanks for the post it worked enough to post a program which I was unable too last night.
I see its a B Axis output which I will setup. So for us who cant afford the machining extension, there appears to be no problem indexing and using the 3D operations by using the Tool Orientation Tab, and a new op for each side. Sorry - 4th Axis is new to me so hope that is the correct way to get things going. I have a lot of parts that need flipping 3-4 times this will be huge for me. Besides, my CAD drawings are not advanced enough for anything more than that, just part flipping on a 4th Axis.
Many thanks.
Message 5 of 15
AdamKunzo
Yes you don't need extension for positional machining.
You can also use wrapped contour or adaptive clearing for your rotary axis. That does not require machining extension.
But it cannot deal with cyclic (360 degrees) geometry and it's basically 2,5+1 toolpath.
Message 6 of 15
boyd.sofield
Ok. Far out. Great. I only make parts in quantities 1 to 4 max (normally) that are complex needing to be flipped so many times. This is huge for me. Also huge because my probe only works about 50% of the time which makes flipping a not-so-nice exercise. But thats another case for another day lol
Message 7 of 15
boyd.sofield
Hi. I have an other quick question. My 4th axis has a brake, which will be operated by a separate hydraulic system needing a command to unlock/lock. I think M10 on M11 Off.
Is the post responsible for this and do I need to edit it to do that? (novice)
Message 8 of 15
programming2C78B
You can also try out the Haas NGC w/ axis post. Most things should be the same.
My post has
case COMMAND_LOCK_MULTI_AXIS:
if (machineConfiguration.isMultiAxisConfiguration() && (machineConfiguration.getNumberOfAxes() >= 4)) {
writeBlock(operationNeedsSafeWorkPlane ? "/" : "", mFormat.format(10)); // lock 4th-axis motion
return;
case COMMAND_UNLOCK_MULTI_AXIS:
writeBlock(operationNeedsSafeWorkPlane ? "/" : "", mFormat.format(11)); // unlock 4th-axis motion
Please click "Accept Solution" if what I wrote solved your issue!
Message 9 of 15
boyd.sofield
Hi. Thanks a bunch for that I tried it out but for some reason it errored. The Post Engineguy put up has been the one I am working with, I actually made my 4th axis move with a program last night. Went in the house told my family, received the normal yawns of boredom and carried on.
Sorry I am really not a post writer, would it be easy enough to insert those lines of code to make my brake come on/off calling a M? To be honest though, the axis I have is tight, and a 1/60 gearing. With the motor holding it I dont know if I really need a brake. Although there will come a day I expect.
Message 10 of 15
boyd.sofield
Guys would anyone know how to pop the M10 brake M11 release into my post that Engineguy kindly uploaded? Gee I read the post scripting manual and yeh, bit too much for this old chestnut.
But hey if there is a different portion of the forums that might be the way. Im just stoked to see a rotating component on my machine so still pretty happy about that tbh
Message 11 of 15
seth.madore
Like this?
G54
M11
G0 B30.
M10
M8
G0 X1.5828 Y1.1912
G43 Z1.5748 H2
Z1.1811
G1 Z0.8465 F39.4
G19 G2 Y1.1676 Z0.8229 J-0.0236 K0.
G1 Y-1.1036
G2 Y-1.1272 Z0.8465 J0. K0.0236
G0 Z1.5748
G17
M9
G28 G91 Z0.
G90
M11
G0 B0.
M10
Post processor is attached 🙂
Seth Madore
Message 12 of 15
boyd.sofield
Aw.....  just like that indeed. Awesome and thanks, thanks to all infact. Im stoked.
Message 13 of 15
texelmicro
Observer
Observer
Do you have the post processor for mach4 with a-axis around x? Without knowing how to write code this is turning out to be really difficult. Appreciate any help!
Message 14 of 15
seth.madore
If you create a Machine Configuration (doesn't need to have a machine model for Simulation) you will get A axis moves from the stock Mach4 post processor.
(2D CONTOUR5 2)
T1 M6
S5000 M3
G17 G90 G94
G54
G0 A0.
M8
G0 X0.375 Y-1.5
I've attached a sample .mch file to get you started, you will need to import it into your Machine Library. Unzip it first and import it in.
Seth Madore
Message 15 of 15
texelmicro
Observer
Observer
Thank you. I watched a video on how to enable the axis and was able to get things up and running
