NC Program Post Process Issues
mpm136
mpm136
Hello all,
I am attempting to use Fusion 360 to create G-code for additive manufacturing. The NC Program that is created from my toolpath does not at all match the toolpath. Regardless of the toolpath, the g-code only contains one small straight line. Can anyone provide any insight into this issue?
serge.quiblier
Hello @mpm136
After creating a setup, selecting a machine configuration file, then a print settings, have you selected the body to slice at the bottom of the dialog?
Then have you right clicked on the toolpath, and generated it ?
Are you able to simulate the toolpath by right clicking and selecting the Simulate option?
If you want others to be able to help you analyse the issue, you should share the file you are working on.
You can either share a link to your Fusion file.
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
or you can save an archive and share it on the forum
Have a pleasant day.
Cheers
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
mpm136
Thank you for the response. I have done everything you have mentioned, but Fusion 360 crashes when I try to simulate the toolpath. I have shared the file I am referencing. Any help would be greatly appreciated.
serge.quiblier
Hello @mpm136
i suspect this is due to the size of the shape.
It's only 0.01mm thick.
I have asked the developers if something this small can be sliced by the algorithm.
Regards
Serge.Q
cam.autodesk.com
serge.quiblier
Hi @mpm136
after looking closer to the issue, here is the cause.
How do you want to deposit a shape that is 0.01mm thick.
with a nozzle which has a 0.05mm diameter?
It's impossible. The nozzle is 5 times bigger than the shape.
Cheers
Serge.Q
cam.autodesk.com
serge.quiblier
Hi @mpm136
and the print settings are worse.
The extrusion width is set to 0.3mm, so 30 time the shape.
Serge.Q
cam.autodesk.com
