NC program generates named view picture
Since the June 2020 update everytime I post process a NC Programm, it generates a .png file for the linked named view of the setup.
Where can I disable this?
I use the Haas Next Gen Post by the way.
Example: I have two setups called OP1 and OP2. The filenames are 1001 and 2001. This is what gets generated:
So it "randomly" added a "2" after OP1 and "14" after OP2.
boopathi.sivakumar
Hi @Anonymous
I could not replicate the issue, Are you using the new NC program to post the g code or by right clicking the setup and post process?, also is it a generic post you are using to post process?
if possible could you share your file here or you can private message me the file
File>Export>.F3d
save the file and reattach the file to this thread.
Boopathi Sivakumar
Senior Technology Consultant
I'm using the NC Programs functio9n to post the files.
From there i rightclick on NC Programms or on the individual NC Program to generate the code.
I've also changed the post-processor to Haas -pre-NGC and Heidenhain, and it still generated the png files.
File is attached.
bump.
ahuppe
I have the same problem, did you solve it??
