Nc.failed
Nc.failed
garymorris405
Nc.failed
garymorris405
Hello there i just finished machining my part in Cam with fusion 360 for the first time and when i click the post process to view the gcode it saves it as Nc.failed with no Gcode in the file. I'm using haas Turning, that is the machines and simulators the are at my school. I'm very new to fuison 360/Cam, CNC machining and not very good with computers but having fun learning 🙂 I'm making the transition from manual machining to CNC and it proving to be a bit confusing. I appreciate any help my friends 🙂  https://a360.co/2QfIyql
Boopathi_Sivakumar
@garymorris405 For post processing in Hass Turning turrent number should be 0, Change the turrent value to 0 in every tool like the image attached or look into this link Turrent Zero
Boopathi Sivakumar
Sr Application Engineer
www.usamcadsoft.in
Facebook | Twitter | LinkedIn
garymorris405
thank you very much!!!! that did the trick 🙂
