NC Code Failed to Post Process Fusion 360 CAM
Every time I am post-processing the code, It's not showing the G-Code, The save file is showing as "1000.nc failed", How to fix this, I checked the Spindle axis also, There is no error in manufacturing also, how to get the code.
I am attaching my work file, Kindly help
Thank You!
jhackney1972
You did not have a Machine Post Processor selected to use.  I just selected one and it posted OK.  Please check if the Post Processor I selected in correct for your machine.  You should also check your simulation, you have some holder inferences in your operations.
John Hackney, Retired
The file you sent me is not opening in my Fusion 360 I am using Student Version, After posting this I tried again now the .nc code filed is saved successfully but after saving I didn't see the G-code, Machine Post-processor I am using is gbrl, I saw in some videos that's why, now the files are saving without error but unable to see g codes, is there any method for viewing g codes from .nc file?
Kindly help!
@jhackney1972 Thank you for your help, if it worked with you can you please send the G-CODE, Please it's really important.
Thank You!
jhackney1972
The generic GRBL post processor  will not work on this file for me.  Your Fusion 360 license should open the file I attached.  I downloaded it and it opens just fine.  Take a look at the Screencast to see how to view the NC Program output using any good Text Editor.  I like Notepad ++ myself.
Thank you @jhackney1972 Sir, For the video, Thank you for the help, I found the problem and I did get the Codes.
