Hello all,
Can someone explain to me the ideal process for multi-part workflow.
I'm looking to machine some parts on a tombstone. About 5 parts per face, 4 faces, so a total of 20 parts per tombstone.
Can someone point me towards something that has the correct work flow.
I.E. Should each individual part be it's own body, should they be their own component etc...
Ideally I'd like to be patterning the tools paths and not have to do a tool path for each individual part. If I use the component pattern, does the part have to be it's own 'component' or just any body?
There is also the question of stock. Should I be modelling each and every bit of stock? Sometimes it's better to keep the model's as small and compact as possible to minimize the file size and stop the computer bogging down.
I'd imagine there are multiple ways of doing this, but are the best practices or generally accepted ways of doing this?
I've tried having a poke around and see if I can find a template or tutorial but can't find much.
FYI - I'm not new to multi-axis milling work, just new to multi-part, multi-axis work through fusion.
Thanks in advance.
