MOVING M08 DOWN A FEW LINES ON HAAS.CPS POST
morgantooldie
morgantooldie
I need to change my M08 from line N45 to line N65 so my coolant turns on when the tool is at the part. No splash guards and coolant is flying everywhere. I am using the Haas.CPS post
  (Drill1)
N30 T1 M6
N35 S2000 M3
N40 G54
N45 M8
N60 G0 X0.704 Y-0.7
N65 G43 Z0.2 H1
N70 T2
N80 G0 Z0.1
N85 G98 G81 X0.704 Y-0.7 Z-0.075 R0.1 F5.
N90 X1.804
N95 X2.904
N100 X4.004
N105 X5.104
N110 X6.204
N115 X7.304
N120 X8.404
N125 X9.504
N130 X10.604
N135 X5.654 Y-1.83
N140 G80
N145 G0 Z0.2to
ivan.stanojevic
Here it is.
Cheers
Ivan Stanojevic
morgantooldie
Is there any way to put the M8 on the same line as the g43?
Also put the M9 on the G53 Z0 retract line
Thank you for your help
ivan.stanojevic
Yes it is but it would require a bit more work to do.
On the other hand if you use only m8 coolant I could set it up in a minute..
Ivan Stanojevic
morgantooldie
i need the coolant to turn on at the same time as it goes to g43 so that the coolant is on the cutting edge at the time of engagement.
i need the coolant to turn off before the tool retracts all the way up because it splashes everywhere and makes a mess.
if you can point me in the right direction i can try to do it on my own
ivan.stanojevic
All right, check the attached post.
Ivan Stanojevic
morgantooldie
works like a charm! Thanks much
