Modifying Postprocessor for Mach4
trains420
trains420
Hello, I use Mach 4 on two machines. I have a problem with tool diameter compensation. In mach4, tool diameter correction can be entered in two ways:
Format 1: G00 / G01 G41 / G42 D__ X__ Y__ F__
Format 2: G00 / G01 G41 / G42 P__ X__ Y__ F__
Format 1 uses D to determine the tool diameter from the tool table.
Format 2 uses P to specify the tool radius (P5, P8, ...)
The point is that the Postprocessor for Mach 4 generates P, and I need to generate D with the appropriate tool number. When there is P in the program, I cannot edit tool corrections in the machine.
Can you help me ? Thank you in advance.
seth.madore
So you want it to post out:
T1M6
G43H1
G1G41X__Y__D1
Is the above correct?
Seth Madore
trains420
Yes. The "D" with the correct tool number must be used wherever "P" is now (at multiple depths).
seth.madore
So, it's going to take a couple small edits. The changes that I've listed below are from a STOCK Mach4 post, so it may differ slightly if you are running any changes
At line 118, we are going to change this:
var pFormat = createFormat({prefix:"P", decimals:(unit == MM ? 3 : 4), scale:0.5});
to this:
var pFormat = createFormat({prefix:"D", decimals:0});
And then we are going to scroll all the way down to line 1234 and 1238
and change the cutter comp sections from:
writeBlock(gMotionModal.format(1), gFormat.format(41), x, y, z, f, pOutput.format(tool.diameter));
to:
writeBlock(gMotionModal.format(1), gFormat.format(41), x, y, z, f, pOutput.format(tool.number));
Seth Madore
trains420
Yes, it looks like it works. Thank you very much for your help.
Stuart-H
to this:
to:
Seth. don't forget the other bit
case RADIUS_COMPENSATION_RIGHT:
dOutput.reset();
writeBlock(gMotionModal.format(1), gFormat.format(42), x, y, z, dOutput.format(d), f );
break;
default:
writeBlock(gMotionModal.format(1), gFormat.format(40), x, y, z, f);
Taken from my PP for Mach 4
Mac Studio M1Max and MacBook Pro M1
seth.madore
@Stuart-H yes, that was the "and 1238" bit, I should have clarified.
1234 was the section for comp Left
1238 was the section for comp Right
Both need changing
Seth Madore
