- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I use Mach 4 on two machines. I have a problem with tool diameter compensation. In mach4, tool diameter correction can be entered in two ways:
Format 1: G00 / G01 G41 / G42 D__ X__ Y__ F__
Format 2: G00 / G01 G41 / G42 P__ X__ Y__ F__
Format 1 uses D to determine the tool diameter from the tool table.
Format 2 uses P to specify the tool radius (P5, P8, ...)
The point is that the Postprocessor for Mach 4 generates P, and I need to generate D with the appropriate tool number. When there is P in the program, I cannot edit tool corrections in the machine.
Can you help me ? Thank you in advance.
