**** mixed up part origin again
jeffescott
Advisor Advisor
jeffescott
All my fault I get it but could we please have the origin indicated during simulations.
Both when simulated in the set up and in the nc programs???
seth.madore
What exactly happened? We show the WCS in the Setup, how would showing it in other places have helped you avoid this incident?
Seth Madore
jeffescott
My last check is to simulate the NC program.
Often it is just a check of an existing program that I am going to run again.
This time I thought I remembered the origin....but sadly had it slightly wrong....
I should have rechecked the set up....but more key stokes and maybe I accidently change something.
Less clicks less errors (i am particularly bad and accurate clicking).
matty.fuller
Perhaps you should consider using Setup Sheets.
jeffescott
Ill check them out again....
I tried way back when....so maybe I'll be more able to figure it out this time.
Thanks for the suggestion
