Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm machining 10 pcs of identical parts in slanted direction, starting from highest to lowest. At the end of the last pattern instance, there is missing a retract when I press button "BLOCK DELETE" on HAAS mill, which actualy deletes rows with "/" at the begining. It causes crash because the first move after last pattern instance is in XY and only after is Z. Can it be solved by post somehow? Like swapping rows or keep the retract in Z in NC code... see pictures please
Lukas
