Missing CAM Libraries/Templates after single user upgrade
toshjones98
toshjones98
Hi All,
I lost all my cloud based tool libraries during the latest upgrade from single user to team based.  If this happens to you the follow link information did not work.  The second link below is to a forum post for the location that worked for me.  You will want to search your "localappdata" folder not the "appdata" folder.   Use "Win+R" then " %localappdata% "   I had a "M" and "M2" folder.  Check both and compare the backup dates before re-importing your libraries.  The latest backup for me was only 5 days old, so I didn't end up loosing anything.  Hope this helps.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Local-tool-library...
https://forums.autodesk.com/t5/fusion-manufacture-forum/five-of-seven-cloud-tool-libraries-disappear...
seth.madore
When you migrate from a Single User to Team Hub, all of your Cloud Assets are placed in a new folder near the bottom of your hub in the data panel:
Seth Madore
