Minimum Z gone from setup sheet when using rotary
Good day!
I have encountered an error that my Setup sheet MIN Z disappears only when (any of) my setup operation contains Tool orientatated WCS.
If I create a setup with any number of operations, not using "Tool Orientation" from the operation properties, the setup sheet posts properly with MIN Z values visible.
If my setup contains even one operation that uses "Tool Orientation" to tilt my workpiece, the MIN Z paragraph disappears or shows zero (0) of value depending on how I generate the setup sheet.
Is there any way around this? Min Z is extremely useful to have when setting up tools.
Regards
Ahola KT
CRANDALLPRECISION
bump,
a.laasW8M6T
Interesting, I get the same issue when I post  stuff with tool orientation(I have my post set to write a comment for the Zmin below the tool call), but couldn't figure out why it was happening some times but not others.
Like you say its an extremely useful tool for checking for collisions etc
Andrew Laas
Senior Machinist, Scott Automation
MNJCNC
Has anyone figured this out? It's driving me crazy.
simspacetn
I started experiencing the same problem today with the current design I'm working on.
I opened a design that I worked on last week and when I post it and ZMIN is there.
I'm not sure what's going on, or what is wrong with my design.
Jerronbao
Observer
Observer
Still a problem 5/8/2024
CRANDALLPRECISION
Its because of tool orientation. The z at that point is not using the setup plane to look at lengths so fusion pulls it out.
Same with our Mastercam and worknc programs. Its not just a Fusion thing.
