- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've already moved on and just put full retraction back on, but I'd like help understanding why this didn't work so that I can avoid it happening again.
When using mid retraction for my surfacing op, the program surfaced the upper angle, then the chamfer for the hole, then it did not pick up high enough and gouged the part when coming across to start surfacing the corner radius.
In simulation, it did not gouge the part, it looks like it barely clears. but the part did get gouged. All features came out great. Offsets were good.
Attached is a simplified cut from the model, can't share the whole model. The problem op is the one labeled Min Retract Gouged Part. This is the second to last op on a lengthy part. Also attached is pic of gouged setup part.
What did I do that caused the software not to clear the part on this step?
