Has anyone managed to mill an internal O-ring groove with a radiused profile using Fusion?
I have attached a photo of a section of a part that I am making. The groove that I have pointed to is 44.5mm diameter, 6mm wide with a 1.5mm radius top and bottom. For some reason the photo makes it look like it's tapered but it's not!
The groove tool that I have is 1.5mm wide with a 0.2mm radius so I want to be able to machine the 1.5mm radius with small stepovers like a 3d toolpath. I have managed to program this manually using a 2d contour by working out the diameter required at each individual stepdown but it takes so long to do this and it's not very accurate.
Ideally we would be able to use a tool that has a 1.5mm radius and just use a normal 2d contour to form mill the groove but we can't get an insert in this size for our grooving tool and as we have many different sized grooves to do over numerous different parts it would be very expensive to have a tool for each radius.
Does anybody have experience of this and can someone recommend a better way of doing this? It's a fairly common machining operation so hopefully someone can help point me in the right direction.
Thanks!
