Mill turn update?
Mill turn update?
DAVISMACHINECNC
Mill turn update?
DAVISMACHINECNC
is there a timeframe yet to add mill/turn to fusion..
As you have been talking about it for years I still have yet to see it come to pass..
programming2C78B
It's been around for at least 5 years,
Please click "Accept Solution" if what I wrote solved your issue!
DAVISMACHINECNC
there are no mill turn machines in fusion unless you create your own... you have options for mill turn and you have turning strategies and milling strategies but no kind of simulations or machines for mill turn...
Asking the fusion support team for any help with mill turn and they tell you that fusion does not support that yet but that they are in the "works"
seth.madore
No, Machine Sim and fully built machine definitions are not yet available in Fusion. What the Support team tells you is only what they're able to say. I'm working with the team(s) responsible for implementing machine simulation for Turning (and 3D tools) and we do certainly have this as a goal. It's still a ways off, I won't state otherwise. It's not a simple task and there's a lot of foundational work to do before it's available to our customers.
Seth Madore
programming2C78B
nowhere in your original message did you specify simulation.
