Blend fails with negative offset?
HughesTooling
Consultant Consultant
HughesTooling
Trying to setup a blend and kept getting a failure and found it failed because of the negative offset. Found I could get it to work if I changed the stepover calculation to on surface. Is this op expected to fail using the defaults and a negative offset? Test file attached.
Mark Hughes
Owner, Hughes Tooling
a.laasW8M6T
As a workaround you can use negative stock to leave in the avoid machine group instead of the Stock to leave in the passes tab:
(view in My Videos)
@oleg.tikhomirov  May be able to better explain what's going on here
Andrew Laas
Senior Machinist, Scott Automation
oleg.tikhomirov
Hi @HughesTooling
Thank you for the feedback. I've created ticket CAM-64897 to investigate and fix the problem. Please use On Surface (should provide very similar toolpath for this example) or workaround suggested by @a.laasW8M6T.
@a.laasW8M6T Thanks for tagging me. I can't really say now why it doesn't work. I think you're right and it's a bug related to machine/avoid surface groups + negative stock to leaves.
Oleg Tikhomirov
Software Engineer
