Mazak inspection results importing issues
Smith_travi
Observer Observer
Smith_travi
Observer
Observer
Hello
I keep getting an error when i try to import my inspection results from my mazak smooth g controller. I have read you need to get rid of the / for a space and that did not solve the problem.
Any help would be greatly appreciated.
serge.quiblier
Hi @Smith_travi
before trying to edit the result file, it would be better to share the error message.
Or take a screen capture showing the message.
Errors on importing can be caused by outdated files, incomplete files, or incorrect file (i.e., import results for part 1 into the session for part 9, not enough results compared to the programmed session....)
Just having the result file is not enough to diagnose, as we have no idea what to check.
Knowing the error will make things clearer.
Regards
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
