Making A Stock in a Milling Setup that is from the lathe
alex_winter
Message 1 of 10
alex_winter
I currently have a tube with a bunch of flats and Holes that I need to machine on a milling machine but I am having trouble defining the Stock in the setup for it. We typically turn it first on the lathe complete and then do milling operations on the mill.  How can I define the stock so it looks like the turning stock exactly?
Would be nice to have a button or a add-in that can make a Spun Profile body that we can use for milling aswell (not just turning).  I currently have to make a sketch on a plane and intersect the body to get the cross-section.  Then I have to edit this sketch to remove the milling features/flats and holes and then revolve it.  Then in setup I select Stock "From Solid"
Replies (9)
Message 2 of 10
programming2C78B
Finish the simulation on the lathe, then save the stock as a mesh. Import it back and use that as your body.
Please click "Accept Solution" if what I wrote solved your issue!
Message 3 of 10
alex_winter
We Currently don't make turning toolpaths in fusion.  I guess I could make a dummy setup and do this though.  I think my cross-section and edit sketch still might be quicker.
Message 4 of 10
programming2C78B
if it truly is a tube, you can just do a Fixed Size Tube as your stock for milling.
Message 5 of 10
alex_winter
Here is a Sample Part.  This one doesn't have any flats.
Message 6 of 10
a.laasW8M6T
I copy the body, then use simplify to delete the hole features.
You can drag a slider to adjust what size holes will be removed.
Design history must be on to do this.
Andrew Laas
Senior Machinist, Scott Automation
Message 7 of 10
alex_winter
We import body's from solidworks (.sldparts) so the part comes into fusion as a single body.   I use to do it this way with 'remove features' but I found it was a bit buggy and you had to be careful what order you remove features in.
These are all good ways.  When I look at the turning spun profile and how it makes it, its just so quick and trouble free.  Kinda wish we could do this with milling.
I have made an add-in that does try to replicate this spun-profile command but it does have some glitches.
Message 8 of 10
akash.kamoolkar
@alex_winter we are actively working on a way to export the spun profile as a sketch in the design space.
Akash Kamoolkar
Software Development Manager
Message 9 of 10
a.laasW8M6T
@seth.madore teased a Spun profile to sketch feature that is coming up
https://forums.autodesk.com/t5/fusion-manufacture/turning-profile/td-p/12557271
you could then use that to create a revolve for your stock body I think
Andrew Laas
Message 10 of 10
alex_winter
I didn't know it was a something that was being worked on.  That will be an exciting day I think.  I would definitely be using it.
