- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I simulate a toolpath that has the table (C axis) rotated but not the head (B axis), the machine simulation doesn't show the rotation on the simulation and shows it cutting C0,B0 but running the code for this will rotate the table on the machine correctly. If I have the head rotated and the Table , It will show it correctly in the machine simulation and run the code on the machine correctly.
I have a .machine file (table-head machine) with Y and C axis on the table and X,Z,B on the head. I have the machine working properly when testing out the axis.
The Toolpath is a contour Milling path with a tool orientation with the X axis (X axis on head as indicated above) reversed to rotate the table 180 deg. I have tried at 90 deg aswell.
