Machine setup orientation
CNCfacile
CNCfacile
Hi everyone,
I'm having a problem with the component orientation on the machine. If the WCS is aligned with the component and machine direction, everything works fine, but when I change the WCS orientation, the component's orientation on the machine also changes, and I can't find a way to orient it correctly. Do you have any ideas?
(view in My Videos)
Christoph_360
Hello
Your definition of the Work Coordinate System in the setup was correct at the beginning.
What you need to do is assign a Tool Orientation Coordinate System to the surfaces you want to machine that are not perpendicular to the Z-axis of the WCS.
(view in My Videos)
Christoph
CNCfacile
Hello @Christoph_360
Thank you for your help.. I already konw that, but this is tje only way?
adrian8B2L2
@CNCfacile
This is my understanding of the current situation, the Z axis of your WCS must be parallel to the Z axis of the machine simulation. So, place your parts and fixtures with a WCS at the centre of rotation and Z parallel to your machines Z axis. Then create a UCS or something that matches the orientation of the physical machine setup with the Z axis of the UCS parallel to the face of your pyramid fixture. You can then program everything using a UCS.
But here comes the catch, you must then modify your post processor to map all the coordinates against your UCS, that way any TWP ( tilted work planes ) operations and 5 axis operations are output relative to your UCS and not the WCS
Oh and god help you if you forget to select your your UCS for one of the operations. 😁 Boom.
Fusion will simulate everything against the WCS, so it will be fine. But the post will then output against the UCS................🤔
